Logik LCD8W22
  • #101958
    clint1974
    Hello
    Tumble dryer starts for 10 seconds or so and then stops with 2 x flashing lights. Manual informs something to do with NTC ? Appreciate any advice.
    #486862
    an NTC is a temperature measuring device used to control the heat
    clint1974
    Thanks, do you know which one i need to change to rectify issue ?
    #486864
    ok depends which lights are flashing
    look at pic below and let me know which ones
    clint1974
    3H & 9H both flash continuously
    #486866
    ok
    thats the ntc mounted on the heater
    so faults can be
    ntc faulty replace heater
    wiring broken between ntc and board
    board faulty
    the next step would be to locate the ntc and measure. it should measure 19.5 K ohms at 20 degrees C
    if it is out of spec you will need a new heater. this should be the one but you need to check with the shop, by sending in your serial no
    https://shop.ukwhitegoods.co.uk/32031612-tumble-dryer-heater-assembly
