Logik LCD8W22
  • #102326
    Listerisonfire
    Hey,
    This tumble dryer has now decided to not work
    I start the cycle and after ten seconds 3 beeps are heard then the start/pause and the empty water start blinking I checked the water I checked the filter and it still doesn’t work
    Any help would be appreciated
    #488361
    at the bottom of the dryer is the float and a pump that pumps the water to the draw. if this pump fails the water fills till the float lifts and operates a switch that brings the full light on and stops the dryer to prevent flooding
    you need to find and check this pump and area for fluff build up etc
    could be
    pump failure
    excess lint build up blocking ducts or pump
    blocked tubes from pump to draw
    electronic board failure
