Logik LFTC60W12, Oven is dead..
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Logik LFTC60W12, Oven is dead..
  • #92908
    HelpImRubbish
    Hello everyone, firstly Merry Christmas!
    Ok so our Logik cooker has a dead oven, no fan, no heat and the LED doesnt light up, but the rest is fine, grill and rings all work ok. Ive replaced the element and its still dead, what would be the next likely fix?
    Best wishes everyone.
    David.
    #452543
    Re: Logik LFTC60W12, Oven is dead..
    Timer on auto perhaps if one is on it.
    Mains terminal block.
    Switch.
    HelpImRubbish
    Thanks for the reply K, it doesnt have a timer so being a n00b at this, the terminal block will most likely be located where?
    Thanks again.
    D.
    #452545
    At the back where power goes in.
    HelpImRubbish
    Ok i checked the wires and everything looked fine. I then took the front knob panel off, inspecting the oven switch i noticed that (looking at it from above) that the top right of the four wires with little plastic covers was burnt through.
    I take it thats the problem and it needs replacing but what worries me is why it burned in the first place, is this a common fault on oven selector switches?
    D.
    #452547
    That’d do it should be this one on it:
    http://shop.ukwhitegoods.co.uk/32016051 … tor-switch
    HelpImRubbish
    Part ordered, thanks K, hopefully this sorts it all 🙂
