Good morning I have a Logik LHP8W18 heat pump dryer. The dryer works for 2-3 minutes then stops, beeps three times and heat level 1 and 3 lights flash. If I switch off at the wall and leave for 10 minutes I can restart but the same thing happens. I have contacted Logik and Currys direct and neither are of any use. I recently had it stored for three weeks, tried it and it worked for a week then fault reappeared.. can anyone help?
Hi Dave, thank you for the reply, unfortunately it’s the heat lights. So the middle ones from your picture, 1 and 3 flashing which isn’t in the manual.
Hi Dave thanks again. Yes it’s completely clean, operates perfectly for a week then stops. Very odd, if it was a faulty surely would not work at all, no signs of condensation in PCB seems a shame to chuck it out
