Re: Logix LBfan12X
Hi Gary,
With this oven turn it to fan oven and select a temperature, say 200C, does the neon light turn on on the front panel? That indicator light sits in a parallel circuit with the fan oven heating element, therefore if the neon gets supply, the element is getting a supply.
Indicator light off = selector fault
Indicator light on = element fault.
Other possibilities could be a burnt off tag or thermal overload stat, but this is a good starting point.
Let me know how you get on!
