Long hose for Hotpoint washer/dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Long hose for Hotpoint washer/dryer
Viewing 15 posts - 1 through 15 (of 18 total)
  • #36500
    kk99ll
    Hi People.
    The Hotpoint washing machine I’ve been looking into buying, appears to be hot and cold but is designed for cold fill because there’s only a cold fill hose supplied and a Y-piece adaptor supplies both valves.
    Can I buy the same kind of hose but longer ❓ , the one’s I’ve seen don’t include the Y piece.
    Thanks in advance.
    #251233
    helo_75
    buy a longer hose ad join it , thats the easy way
    #251234
    Re: Long hose for Hotpoint washer/dryer
    If the machine ‘appears to be hot & cold’ then it will have two valves on the back marked H & C.
    If it has then it was not designed for cold fill but has been fitted with a ‘Y’ piece to convert it to fill cold through both hot & cold valves, possibly due to a lack of a hot water supply at its previous installation, ( I’m guessing that this machine is second hand).
    If you have a hot & cold water supply then you can connect it to both using two separate pipes.
    Longer pipes are readily available at B&Q etc.
    kk99ll
    It’s brand new, and it’s a cold water machine, it’s got this Y connector hose as previously stated
    #251236
    Has it got two valves on the back. πŸ˜•
    It may be a recent innovation, what is the model and serial number number?
    If the machine is supplied from new with a single hose then it should not need a Y piece, that is only required to convert a hot & cold fill machine to cold fill only.
    If the machine has two cold valves then I would expect the machine to have two hoses, otherwise why supply a Y piece with only a single hose?
    However, as I mentioned you can get longer hoses from several places, you only need one Y piece attached to the cold tap, then two hoses from that to the machine.
    helo_75
    jim… its the new heater box model
    they require two cold fills, as they have the flushing valve…. just fitting the y hose at the back and extending it with a single hose is sufficient
    they changed it again, and put the flush on the heater box again
    this time, its the indesit box with a filter at the back ( and yet another different eprom)
    #251238
    kiddo66
    And just to confuse things more there is another new heater box out!
    #251239
    helo_75
    and a new plastic welded tub to match
    lmao, oh the joy eh
    #251240
    So what the OP needs is another hose and a 3/4″ BPI jointing piece then………. :rolls:
    helo_75
    yup
    #251242
    πŸ˜€
    :p45:
    #251243
    kk99ll
    I will post a pic then you know exactly what I mean πŸ™‚
    #251244
    helo_75
    no need, penguins told u what u need
    #251245
    Penguin45 wrote:So what the OP needs is another hose and a 3/4″ BPI jointing piece then………. :rolls:
    Much better to just get a single, longer hose, dirt cheap and far less possible leak points.
    He can’t – it’s one hose with a bifurcated end to feed two valves.
