Re: looking for an under counter fridge only, 84-88cm wide
Hi TN
The minimum width currently available is 50cm, Whirlpool used to produce a 46cm but I havn`t seen any around for a while. No such thing as a bespoke fridge manufacturer either I`m afraid. The only thing I can suggest would be to put the biggest 60cm width larder fridge you can find into the space unless you can gain an extra 13cm to be able to install two 50`s side by side and then reverse the door opening on one of them.
