Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Looking to buy Condensor Dryer and need advice please!
- This topic has 11 replies, 6 voices, and was last updated 21 years, 1 month ago by
admin.
February 18, 2005 at 6:01 pm #8022
KeymasterHi guys…
Im looking to buy a Condenser type dryer which will be placed in my garage but I have a couple of concerns / questions… any advice appreciated please:
(1) As the dryer is going to be in a non-heated garage, is everything likely to get covered in condensation when its cold outside?
(2) Referring to the above question, I am led to believe that condenser dryers are worse for this than vented ones – is this the case?
(3) What machine would you recommend for around £300? I have been looking at the Hotpoint CTD80P today but have just found a website (Quality Electrical Direct) that sells the Bosch WTL6307 for just over £300… am I on the right lines??
(4) Silly question maybe but I last had a tumble dryer years ago that regularly shrunk clothes and generally damaged them.. Im assuming they have got a lot better since then…. Is this the case or am I still going to see problems?
(5) regarding the efficiency of condenser dryers – how much longer do they take to run a cycle in comparision to a vented dryer?? Is there any other disadvantages??
Any other advice appreciated please!! 😉
Cheers
Steve
February 18, 2005 at 8:15 pm #126490indesitcouk
ParticipantRe: Looking to buy Condensor Dryer and need advice please!
CTD80 is a good machine, I have one myself. Nothing has gone wrong with it yet, touch wood. Around the £300 mark is about right.
February 18, 2005 at 8:30 pm #126491Martin
Whilst the Hotpoint mentioned is a good value and a fairly reliable machine, its use in the environment you intend is not a good idea 🙁 They are vulnerable to damp and tumble dryers generate a lot of that, so a very risky product. Far better the Bosch in my opinion as it has no known susceptibilty toward that situation 😉
February 19, 2005 at 10:05 am #126492Merritt
I actually remembered to login this time!
Thanks for the comments guys… do you have any thoughts on the other questions please i.e. condensation, effieciency etc? Im especially concerned about the condensation issue because I don’tr want everything in my garage going rusty! 🙄
CheersSteve
February 19, 2005 at 10:16 am #126493Penguin45
The easiest way to avoid the condensation isssue is to buy a vented dryer and put the hose through the wall. Vented driers are genearlly more energy efficient, as well as being a damn sight simpler!
Penguin45.February 19, 2005 at 10:16 am #126494Martin
Merritt,
Condenser dryers are not as energy efficient as vented dryers owing to the complexities of their operation, but come close nevertheless. But as it is being installed in a garage perhaps you would rather consider buying a vented machine and knocking a hole in the outside wall and installing a vent kit?
Also, lay linoleum or similar waterproof floor covering onto the bare concrete floor to prevent rising damp should the floor not have an adequate DPM 💡
February 19, 2005 at 10:18 am #126495Penguin45
ParticipantSnap!
February 19, 2005 at 10:19 am #126496Martin
Great minds think alike eh Mr P ??
February 19, 2005 at 10:21 am #126497Merritt
Excellent, thanks…
Since I have only been looking at condenser dryers, do you have any recommendations for good quality, reliable vented dryers that work well is this sort of environment please?
Cheers
Steve
February 19, 2005 at 10:33 am #126498Martin
BOSCH every time!!! 😉
MartinFebruary 19, 2005 at 10:48 am #126499clivejameson
Considering the invironment its going in, there’s a good case to buy a basic machine like a White Knight or a Creda for example…they are very cheap to buy, very basic and therefore reliable, and they will dry your clothes quite adeqautely.
As to which model well its worth buying a model which has a reversing action to avoid a lot of creasing.
The only important thing to consider when installing it is to make sure the vent hose is as short as possible, preferable less than three feet (1 metre). Any longer than that and the moisture in the exhaust may condense within the vent hose causing problems.
All in all the cheapest and easiest way to go really 😉Clive
February 19, 2005 at 11:28 am #126500Merritt
Guys – thanks for all your help… I have now ordered a BOSCH WTA4408.. It came to £270 all in including delivery and will be here in 5 days.
Clive – thanks for your last post there, unfortunately I had already ordered!!
Thanks again for everyones input.
Steve -
