Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Loose Bearing Insert
- This topic has 6 replies, 5 voices, and was last updated 15 years, 3 months ago by
Phidom.
January 8, 2011 at 11:47 am #60035
ParticipantI have put new drum bearings in a Hotpoint WD62 washer dryer but there’s still lots of play in the drum which I can now see is due to the alloy bearing housing insert being loose in the plastic drum moulding. Is there any way to repair this? I’m wondering about drilling a series of holes round the periphery of the insert and injecting epoxy resin. It’s frustrating having to scrap the machine after spending time on it. Before I discovered this problem I did quite a lot of cleaning, as there was a lot of rusty greasy gunge round all the inside surfaces of the drum, spider and tub. 🙁
January 8, 2011 at 12:51 pm #340498Martin
ParticipantRe: Loose Bearing Insert
Phidom wrote:I’m wondering about drilling a series of holes round the periphery of the insert and injecting epoxy resin.
I seriously doubt any success will come of it unfortunately. 🙁 The ally collar is in effect heat welded to the polypropylene in manufacturer so the majority of that collar, as a rule, elongates the area where it sits. And also the black aluminium deposits don’t allow resin bonding much adhesion that wont give way after half a dozen washes anyway. 😥
January 8, 2011 at 4:27 pm #340499iadom
ModeratorRe: Loose Bearing Insert
It is quite common to see this, mainly on the washer dryers but also on the higher spin speed washing machines.
As Martin says, no effective repair. 😉
If the marks down the back of the drum are a rusty red then crack on, if they are a grey and sludgy, run a mile.
January 8, 2011 at 8:45 pm #340500Phidom
The marks in this case were rusty and the front bearing had collapsed. At least scrapping this one will give me a donor heater I need for another machine I’m building for myself.
January 10, 2011 at 11:35 pm #340501leavemetogetonwithit
Once I had the bearing housing fracture when I was hammering out the front bearing. The front 2cm or so of the housing came away as a ring. I araldited it back in place and it lasted very well. Your situation there is of course more difficult. I would have been tempted to give it a go by drilling holes around the periphery from the back and inserting bolts or long self tappers. But not if water had been coming through that way.
Mike.January 11, 2011 at 6:55 am #340502timdowning
Ive tried this on two occasions, unfortunately it dosen’t hold out.
January 12, 2011 at 8:47 am #340503Phidom
I have told the customer it’s BER. Apparently I changed the tub once before on this same machine but I can’t remember why.
