Loose concrete block damaged Bosch wfb 2004
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Loose concrete block damaged Bosch wfb 2004
  • #67436
    stuartm25
    The concrete block on my Bosch WFB 2004 GB/33 has worked loose and damaged (dented)the outer drum. When the washer is working you can hear hear a scraping noise every time the inner drum revolves as it catches on the outer drum.I don’t think there is much I can do about it but is this likely to damage the washer and shorten it’s life?
    #367442
    Re: Loose concrete block damaged Bosch wfb 2004
    Yes, in a word.
    I wouldn’t be using it TBH.
