Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Loss of power to ADP 8224 dishwasher (possibly SMEG)
- This topic has 3 replies, 2 voices, and was last updated 8 years, 6 months ago by
Demby.
September 22, 2017 at 1:52 pm #92217
Demby
ParticipantI have lost all power to my machine. After checking the fuse in the mains plug, I replaced the on/off power switch. Current is present one pin of the four, when the switch is in the off position., and in two pins of the four when in the on position. The remaining two do not appear to be carrying current. I cannot get hold of a repairers manual and have no idea which way the current is supposed to flow but would expect more action at the switch. I understand that the machijne may have an internal fuse but I have no idea where it is. I am loath to start undoing screws in case springs start popping out . If anyone has any ideas of possible faults , I would be grateful. Secondly, there is a massive spring built into a unit in the back of the control panel.I dont know if it is a door switch, but in any event, when I opened the door before the machine broke, the panel lights were still illuminated, so it clearly doesn’t stop current flow at the on/off switch. This has been going on for a week now. I cannot locate a tradesman, so if anyone has any ideas, I would be really grateful.
Thank youSeptember 22, 2017 at 2:01 pm #450600kwatt
KeymasterRe: Loss of power to ADP 8224 dishwasher (possibly SMEG)
Check the door lock microswitch, the bit you’ve labelled “What is this unit for?”.
September 22, 2017 at 3:43 pm #450601Demby
ParticipantRe: Loss of power to ADP 8224 dishwasher (possibly SMEG)
Thanks for the pointer Kenneth. My concern is that when I used to open the door during a cycle, the machine stopped, but the panel lights always remained on. For instance, you need to open the door to access the controls and the panel needs to be illuminated so that you can set the programme. I’m not getting any panel illumination. Is the door switch likely to be the problem? Not knowing how the current flows from the power switch, I can’t check for continuity further down the line
September 22, 2017 at 3:46 pm #450602kwatt
No, it’s further into the machine in that case then.
Door wiring harness would be a good bet.
