Lost Power to Machine
  • #23318
    busybeaver
    Model GWL11US
    Washed a load of clothes. Machine went through cycle. I opened the machine and found some suds as well as a spot of water. I tried to turn machine back on to run through the spin cycle to run off the excess water, etc. When I went to press the power button, nothing happened. Pulled the plug to “refresh” the machine. Waited and replugged in and same result…nothing. Ohmed out motor which checked out good at 32 ohms, power going to the washer is fine, drained off excess water manually and tried to power on again with the same results.
    I am to the conclusion that the motor control board is bad and I need an new one. I would like a response perhaps to back up my theory or perhaps someone to make a suggestion as to what to test next…
    Thanks in advance…
    #197733
    Re: Lost Power to Machine
    busybeaver wrote:Model GWL11US
    Very few of us on UK Whitegoods are familiar with US made washing machines. Perhaps you could tell us what make a GWL11US is? It’s probably a top-loader is it?
    #197734
    Pump blocked or faulty possibly?
    This is a US spec Fisher + Paykel top loader. I regret that I have no tech info specifically for the 110v machines, but a read of Australasian Forum (next forum up) should be pretty revealing.
    bigsmokepiker
    If no power more than likely Motor Controller (Main PCB )
    Main reason this happens because of faulty Divertor Valve
    IE The thing next to pump
    Divertor craps out & takes The PCB with it
