Loud knocking noise on high spin: ISE w1607w
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Loud knocking noise on high spin: ISE w1607w
  • #89923
    Charliedurrant
    My 2011 ISE W1607w washing machine has always made quite a racket.
    So after changing the water pump and the door seal I thought I’d gather opinions on what it might be? It’s a definite knocking and as I said it’s now a new issue.
    Here’s a video of the noise:
    https://youtu.be/ix6VKgK_dQs
    I can’t see (hear) where it is coming from! Worst on 1400 spin, less on 1200, nothing on 800…
    Thanks in advance for any replies.
    Charlie
    #443042
    Re: Loud knocking noise on high spin: ISE w1607w
    Maybe the heater is not secure between the inner drum and outer tub?
    #443043
    Charliedurrant
    Martin,
    I’ll take a look and report back.
    Thanks,
    Charlie
    #443044
    Charliedurrant
    Here’s a video of an ASKO machine with the same noise all be it quiter as the machine is together. The ISE is basically an ASKO machine with some differences.
    https://youtu.be/GYTk716A_r4
    And also (noisier)
    https://youtu.be/EUQIAyu95fY
    #443045
    Charliedurrant wrote:Here’s a video of an ASKO machine with the same noise
    Wow, not the sort of machine you would want kids in the same room with. Will that drum flopping about severed fingers an inevitable outcome. I’ve never seen these machines in action before but the first video the bearings/drum shaft are the issue. As might well be the case with the OP’s machine?
    #443046
    Charliedurrant
    Yes, the way the drum separately moves around the casing at the front is certainly different. Surprisingly though there is no forward movement just side to side movement so fingers are not at risk.
    #443047
    Charliedurrant
    I thought mine sounded like the first ASKO video as well..
