low cold water pressure
  • #28190
    Tom
    ❓ I’ve had cases recently washers & dishwashers where cold water was supplied from tank in loft (single storey) resulting in intermittent behaviour likely due to time out on the fill.
    There seems to be a reasonable flow of water.
    Is there any known mod (like a different fill valve)?
    Does anyone know of new machines with the all mechanical timer?
    Many thanks in advance,
    tom
    #217301
    smartin
    Re: low cold water pressure
    they used to put flow control washers in the valves behind the removeable filters, i used to take them out and that improved the flow but customer must know incase they take machine elswhere with higher pressure smartin
    #217302
    Bryan
    Tom , as far as I know all cold water should be fed directly off the mains water supply. Storage tanks are for topping up central heating and hot water tanks etc.
    I wouldn’t want to drink water that came from any sort of storage tank and any appliance should be fed from the same source.ie mains supply.
    HTH
    Bryan
    #217303
    Unless the have spring water, then you need a tank in the loft.
    Tom
    Thanks for comments.
    Situation usually arises in rural areas where water is pumped from a well into a tank in loft. Cold water for drinking & cooking taken directly from the pump line.
    As I retail appliances I’ll keep looking for machines (maybe with older technology) to cope with this niche situation.
    I’ve been wondering if washing machines with hot & cold fill might have to allow enough (longer) time for filling; a hot fill will almost always be from a low pressure supply.
    tom
    #217305
    dpm
    Two words: boost pump.
    #217306
    spanner51
    A few years ago I saw a few machines fed of a cold water tank in a commercial situation. This was done on machines which didnt have the type ‘A’ air gap, to comply with the WRAS regulations.
    The customer had bought a domestic machine to save money, so I used to install a Stuart RG25 pressure pump, which solved the low pressure problem.
