The lower sprayer arm on my Baumatic BDW14 is not going round so the lower tray doesn’t get washed.
I have checked the arm which is perfectly clean.
The machine has an option to use just the top tray which prevents the bottom sprayer bar from operating so I wonder if there is an electrical fault that is causing it to act as if this is activated (the 1/2 option light is NOT lit)
Is there a way to reset the machine to check this is not the case or any other ideas.
TIA
