lpr600 d/washer
  • #71869
    dopper
    w/pool type 4 flashes = drain problem but it drains ok when reset it will work ok for a few weeks, had a water chamber fitted abouit a year ago, anyone advise maybe preesue switch
    dop
    #382626
    Seamy
    Re: lpr600 d/washer
    water in base perhaps?
    #382627
    johnnyj
    Re: lpr600 d/washer
    Could be the owi sensor they get gunged up, sometimes cleaning them works or a new may be required, JJ
    #382628
    aqualectric
    Re: lpr600 d/washer
    JJ is right – 4 flashes is OWI failure (that’s the black grid on the right of sump cavity). The fault occurs when the machine has drained and the OWI (being full of crud) tells the PCB the machine sump is still full. The machine continues to drain until the PCB “times out” the drain cycle – 4 flashes = no drain in the time allowed. Thoroughly clean the OWI with a toothbrush; I always remove them to clean as some of the hard fat can move and the problem can reoccur. 😉
    HTH,
    Steve.
    #382629
    dopper
    Re: lpr600 d/washer
    cheers will check that
