lsv66 Ariston Dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum lsv66 Ariston Dishwasher
  • #8897
    Fife Flyer
    Hi, I’m having problems with my LSV66, water is not heating, so timer sticks. Looking on the site it looks like either a thermostat or heating element problem, can anyone help. P.S. if it is these that are faulty can I repair the machine myself?
    #130993
    Re: lsv66 Ariston Dishwasher
    That is a question that only you can really answer, do you have any electro mechanical experience, do you have the required test equipment?
    Whilst it could be the heater that is at fault the thermostat itself should not prevent heating, however a safety stat would. Fault could also be due to control timer or breaks in wiring harness, or other component failure.
    If you do decide to take a look please remove the mains plug before you do and remember that most modern appliances have some very sharp edges.
    Can you see any obvious fault on the heater, does it look warped or split ?
