Lux erl6297xsi f/f error code EF
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Lux erl6297xsi f/f error code EF
  • #66326
    mbdas
    Hi been to this and getting EF as soon as u plug it in but the evaporator fan motor seems to be running may be a bit fast,just wondering if anyone has had same problem as not sure which to replace pcb of the fan motor, first one of these I’ve seen.
    Thanks Mark
    #363804
    Seamy
    Re: Lux erl6297xsi f/f error code EF
    EF means Evaporator Fan, some of these run a function test when plugged in, may run defrost heater, fan, compressors etc for a while.
    Theres a pretty good service manual available for them if you have access to TDS, with tests routines, diagnostics etc.
    #363805
    mbdas
    Hi got old Tds 08 v2 but that model not on it , I’ve put it in service mode but the evaporator fan is running all the time as u put it through test mode,I would say it’s the module but which one controls the fan motor?also the pnc is not listed on lux web site
    928465049-000 also the guy has been monkeying around with it and I’ve got a sneaky feeling it’s half inched. 😕
    Mark
