Hi I am trying to get hold of the drum bearings and bearing seal for this machine.
Connect have sent me 50246816008 skf6205zz for the front and 50246817006 skf6204zz for the rear.
These bearings fit the tub back ok but they dont fit the drum spider. The rear bearing seems to be ok but the front bearing is too big for the shaft.
Any help would be great as this machine has been in bits in my garage for a while now and I need the space back.
Cheers Ray
The spider that I ordered from connect was dst 5045170617417. This is a perfect match for the old one
Hi Thanks for the reply. I ordered that spider first but its not the same as the one that came out of the machine. The one that came out is the same size all the way along the shaft.
Cheers Ray
