Lux showing E66
  • #74985
    PNC:914511301, part number 973914511301009, out of stock even at Lux and rather expensive. 😥
    E66 =relay stuck closed.
    Has anyone managed to successfully replace the heater relay on this board?
    Re: Lux showing E66
    not done it but should be ok if it is only relay
    have you looked for earth faults? I only say this because if motor gets wet board sees this as a motor triac short. Not sure if heater is live or neutral switched so theory may not apply.
    i would connect a lamp to the heater wires and see if it helped
    also you should be able to get a reading across the relay if its faulty
    hope it helps
    dave
    #393497
    Re: Lux showing E66
    Customer had already fitted a new heater after reading some ‘advice on the net’ :rolls:
    He has decided to bin it as this machine has already had a new pcb under warranty. 😥
    AMS
    Re: Lux showing E66
    Had one of these a few weeks ago at a neighbours house. Gave all the relays a little “percussion adjustment” with a screwdriver. Fault went away. Advised them that it might not last and the only alternative is a new pcb. Saw them the other day – machine still going strong.
    #393499
    Re: Lux showing E66
    AMS wrote: “percussion adjustment”
    lol
    Specialist01269
    Re: Lux showing E66
    Percussion Adjustment, I like that Lol.
