Re: Lux Washer Dryer Error "EH0"?
EH0 – Voltage or frequency out of the normal values
go figure… This is only displayed to the user,if you go into the diagnostics you can read the actual code which will be:
EH1 Power supply problems (incorrect / disturbance); PCB faulty. Wait for frequency nominal conditions. OFF/ON
EH2 Power supply problems (incorrect / disturbance); PCB faulty. Wait for voltage nominal conditions. OFF/ON
EH3 Power supply problems (incorrect / disturbance); PCB faulty. Wait for voltage nominal conditions. OFF/ON
In short, check the customers voltage is correct but more than liekly a new pcb req. ALways worth meggering the dry heaters on these though as even a slight earth leak causes all sorts of eroneous errors.
