Lux washing machine EW1246W, 914665010
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Lux washing machine EW1246W, 914665010
  • #25432
    roly16
    Serial no. 237……
    Can anybody solve this problem? According to the TDS disc the timer knob has been superseded to part 1246069403, which is what I ordered, and you’re supposed to just take the spring out and fit the new knob. However the old knob is a clip-on type onto the timer shaft, whereas the new knob is a traditional nut-fixing type onto a threaded shaft and won’t fit .
    If you enter the old part no. into Connections [1240811602] it automatically supersedes to the new one.
    Any help on this would be appreciated.
    Geoff
    #205836
    chichele
    Re: Lux washing machine EW1246W, 914665010
    not sure whether its worth checking pt no but according to tess
    I make knob cover 1245154008 and knob 1240810604 neither part
    appears to superceed and there a no bulletins relating to it
    Regards chichele
    #205837
    Alanj
    Geoff,
    is it not the thermostat knob that is the push on type? DST1245389000.
    Alan
    #205838
    Alanj
    Geoff,
    try typing LUXEW1246 into Connections online and you will get a list.Think this might be what you’re looking for – 5031680208689.
    Alan
    #205839
    roly16
    Thanks for the help everybody. What I did is order the timer knob in error when what I need is the selector knob. It’s confusing on this machine as you set the program with a selector rather than the timer which only has an indicator dial.
    The correct part no. is I think 1242162020 [connections 5031680208689] as some of you have said. Chichele; this is a substitution from 1240810604; have a look on the TDS offline disc.
    Thanks everybody.
    Geoff
