Home › Forums › Public Support Forums › Help And Support › Other Appliances › Luxair Extractor Fan CVD ST pulses when lights on
- This topic has 9 replies, 4 voices, and was last updated 9 years, 5 months ago by
grapegirl.
October 17, 2016 at 12:24 pm #89612
grapegirl
ParticipantHi there I have a Luxair extractor fan. The fan works just fine until i turn the lights on and then it pulses. It doesn’t matter what speed setting it’s on. Any ideas what is happening?
October 25, 2016 at 8:37 am #441859electrofix
ModeratorRe: Luxair Extractor Fan CVD ST pulses when lights on
do the lights pulse as well ?
October 29, 2016 at 12:26 pm #441860grapegirl
ParticipantRe: Luxair Extractor Fan CVD ST pulses when lights on
Yes. Both work well on their own but pulse when on together
October 29, 2016 at 1:08 pm #441861electrofix
will be the pcb faulty
dave
October 31, 2016 at 9:14 am #441862grapegirl
Thanks – is that easily fixed?
October 31, 2016 at 11:27 pm #441863electrofix
you would have to ask luxair for a price and availability but should not be difficult
board may be able to be repaired but i would have to see it
January 9, 2018 at 9:31 pm #441864AgentX
I have the SAME problem. The lights are fine, the extractor is fine.
Both on at the same time and the lights stay on fine but the extractor pulses at any speed. If I turn off the lights the extractor is fine.Looking at the generic circuit dragram on this site for cooker hoods it shows
1) a 12v transformer for the lights
2) a controller board that supplies the fan (assume its mains) and the light transformerWith this type of fault is it always the controller or could it be the step-down lighting transformer?
It is hard to open up CDA curved glass chimney type hood to expose the light transformer and controller board (is it part of the keypad?)
The board level repairs are they bad electrolyics I should look for?
Did the OP get their problem fixed?
Thought I’d ask before trying to take things apart!
Unit looks like this with halogen at the rear as seen in this photo
https://www.amazon.co.uk/Cooker-Curved- … B007OXVJKQ
Not sure how to open it up or find the part number its not on the Amazon listing.
January 9, 2018 at 9:47 pm #441865electrofix
its not the transformer it will be the board
its the power supply to the board could be bad electrolytics depends on the type of power supply
January 18, 2019 at 1:50 pm #441866bobzilla7
ParticipantDid you get this fixed? I have exactly the same issue.
If it was the board, where is that located and can you get a replacement?
Thanks!
January 18, 2019 at 2:02 pm #441867electrofix
Moderatorfrom the state of this thread this looks like a common problem. none of the posters above have got back with a solution. I still think is a board power supply problem, as on their own they are ok, but turn them both on and it fails. imagine a low battery that can power 1 item but gets too low when you turn 2 items on
part for this will probably have to come direct from luxair themselves unless the board can be fixed
