Magtag admiral T/D
  • #41972
    rocker
    Relisting as rang maytag they are unable to help me on this….
    having problem fitting belt, there is a (starting handle) type of metal with a pully wheel fitted, the long shaft goes into locating holes in bracket of motor, but it dosent hold tight, so when trying to line up belt and rotating drum by hand belt pops off, can only think this may be the fault!!
    also not sure if i have sping in correct position,can anyone give me a drawing of how this part and spring locates.
    Cheers John.
    #271890
    DentedPorsche
    Re: Magtag admiral T/D
    Hiya,
    Do you have the model number?
    Brian 😀
    #271891
    rocker
    Re: Magtag admiral T/D AYE2200AGW
    Sorry Brian model No AYE 2200 AGW
    #271892
    DentedPorsche
    Hiya,
    Sorry, I can’t find a Maytag equivalent for that model number.
    Brian 🙁
    #271893
    rocker
    Brian, thanks for looking John
    #271894
    rocker
    *bump*
    #271895
    ELDAR59
    http://www.partadvantage.com/store
    this site has the model listed john, the drawing is not altogether clear.
    see what you make of it.
    cheers.
    #271896
    Our friends over at ApplianceJunk.com have a suitable service manual listed HERE.
    rocker
    Alf & Chris, many thanks to both of you, with your help I should be able to t sort out this problem. John
