Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Main motor pulley not sure if this piece is part of it
- This topic has 13 replies, 3 voices, and was last updated 4 years, 9 months ago by
Haramo.
July 4, 2021 at 7:52 am #99747
Haramo
ParticipantWe have a AEG model T59870
Type P502867 tumble dryer. Prod no: 916 096 618 00
as It seems the pulley needs to be replaced often , this time I saw a ring next to the engine . I used A tool to get it out .
see picture ( will follow)what I mean .
I’m not sure if this belong to the motor or it’s melted plastic from the old motor pulley.
July 4, 2021 at 8:00 am #477741Haramo
ParticipantI can’t upload the picture , it’s to big.
see Dropbox link ( no Dropbox required )
https://www.dropbox.com/s/h03yt1rzl57jz6i/Airdryer_pulleypart_IMG_8292.jpg?dl=0
July 4, 2021 at 9:07 am #477742electrofix
Moderatorthats part of the old pulley
pullt part no 1250125208
https://shop.ukwhitegoods.co.uk/1250125034-zanussi-others-tumble-dryer-belt-pulley
make sure you clean the shaft well to make sure all residue of the old pulley has gone
July 13, 2021 at 7:27 pm #477743Haramo
ParticipantThanks a lot, I took the guess and removed that piece.
Thank for the support.July 17, 2021 at 1:33 pm #477744washingmachinewoman
ParticipantIf pulley carries on needing to be replaced often, I would suggest something is not running true.
One of the likely culprits could be the drum rollers. Should save you money in the long run as you will not be changing the pulley every 5 minutes
Cheaper on eBay, do a search on 1364059004. I would steer clear of second hand ones though.
July 17, 2021 at 2:03 pm #477745Haramo
ParticipantDear thanks for the info. I don’t seee this part in my motor or is it situated elsewhere? I only see the black pulley.
July 17, 2021 at 2:03 pm #477746electrofix
Moderatorwashingmachinewoman wrote:If pulley carries on needing to be replaced often, I would suggest something is not running true.
thats the drum roller not the belt pulley
July 17, 2021 at 7:31 pm #477747Haramo
ParticipantDave , if I undertand Electorofix correctly, he said that i need to replace the drum roller, as my pulley gets damaged after one week… .I’m just not sure where to find the drum roller.
July 17, 2021 at 7:33 pm #477748Haramo
ParticipantI mean , washingmach not electorofix
July 17, 2021 at 9:47 pm #477749electrofix
Moderatorif the drum roller had gone it would not damage the belt pulley in that way. the front of the drum would run lower down but its got to wear a heck of a lot to make any difference. a few mm is not going to alter things so if it worn any more your either an industrial laundry or the pully has a design flaw and it would be visible
did the new pulley come in a genuine zanussi/aeg packaging ? Am wondering if they sent you a copy part and passed it off as gen. Or did you get it direct from AEG ?
July 18, 2021 at 1:44 pm #477750Haramo
ParticipantThis is the name on the invoice :
Zanussi Spanrol breed 22×50 -as 8mm- 1250125034
google translate:
Zanussi Tensioner wide 22×50 -shaft 8mm- 1250125034
July 18, 2021 at 1:47 pm #477751Haramo
ParticipantAnd on the picture of the webpage it mentioned : original
August 4, 2021 at 6:56 pm #477752Haramo
ParticipantDear
To confirm the piece that should be part of previous pulley .
I read in the manual :In some models, there may be a plastic spacer between the rear bush and the motor. During assembly, take
care you reposition it correctly.
does this speak about the side where I took out the old pulley ? If yes then chances is that that little piece should be put back , after cleaning it from the plastic melted on itAugust 4, 2021 at 7:54 pm #477753electrofix
Moderatorthats talking about the motor not the pulley. probably to extend the motor so it will fit and pivot correctly
