Re: Main oven door not opening fully
I seem to have exactly the same AEG Competence oven with exactly the same problem, except on mine, the lower right hand hinge of the main oven door has broken (/dropped) instead of the left. Pulling the door out a little on the RHS allows it to open fully.
Are the part numbers quoted still valid for the RHS, or are they different to the LHS?
I read advice on the website about replacing both sides together so maybe this is still advisable?
I also read the self-help pages about replacing oven doors (http://www.ukwhitegoods.co.uk/modules.p … ge&pid=309) and wondered if this is relevant to top-opening doors? The thought of ripping my tendons out worried me a little 😯 ! But if this is “basically a screwdriver job” then I should be ok. Any advice about the sequence to dismantle the door to replace the hinges would be very welcome, however.
Many thanks.
