Main Oven On Belling XOU 594 Not Working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Main Oven On Belling XOU 594 Not Working
  • #54318
    Sutwam
    I have just moved house and the Belling XOU 594 main oven doesn’t work.
    When I turn the knob there is very little resistance, there is no noise suggesting the oven is trying to work but can’t.
    The smaller top oven works perfectly well.
    Is this a fixable problem or do I need to replace the oven?
    #319195
    gandh1
    Re: Main Oven On Belling XOU 594 Not Working
    you could repace the selector switch or thermal regulator but theres no guanrantee that is the reason.
    your best option is to call out an engineer, because guesswork can be expensive, and otherwise you then have to work out how to replace the part too…
    alternatively of course the oven could be in auto/time-not-set mode 😛
    #319196
    Seamy
    Have to agree with previous poster, most likely clock not set properly.
