AEG LAVA-COMBO 1000
1. How do I remove the large 5 spoke pulley?
I have tried turning the brass coloured Allen key bolt surrounded by a collar anticlockwise but that’s not budging. Also tried the other direction. Which way to loosen?
I need to remove the pump assembly cover plate which holds the pump rotor etc. This part is corroded through, causing a leak.
2. Where are the Fuses for the pump and drum motors located?
The washing machine power light lights up when on, but there is no machine operation.
Will be pleased to get some guidance.
