Manual for Diplomat APM6842 and recommendations for a replacement
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Manual for Diplomat APM6842 and recommendations for a replacement
  • #101604
    jeeti
    Hi would anyone be able to help source a manual for a Diplomat APM6842 50/50 fridge freezer? Mine is 20 years old and I need it replaced but without knowing the exact dimensions Im worried to order a new one and it doesnt fit and slide into the integrated cupboard space its currently in. Also if anyone can suggest a make or model (and provide a link) of a good match, it would be of great help. thanks
    #485394
    don
    There are no manuals avaiailable due to it’s age.
    Luckily I know you have a standard integrated fridge freezer which has a split of 50:50 with sliding hinges as this very model came up back in 2017.
    So any integrated 50:50 at 177cm tall with sliding hinges will fit.
    A quick search and a good lot here on A.O. will do the job nicely. Don’t forget to factor in delivery installation and removal of the old appliance.
    Don
    #485395
    jeeti
    Hi Don thanks so much for the quick response. Can I just check is sliding door the same as sliding hinge as AO have lots with sliding door fixing but only 1 with sliding hinge fixing. Am I limited to just one choice, do you know? And thanks for the prompt re installation and delivery, those 2 costs alone are similar to the cost of a new fridge itself. thanks again
    #485396
    don
    I don’t know what that Frigidaire is doing there but it will also fit the same as the ones in the AO link.
    Don
