I wonder if any of you would be able to supply me with the service manual for the Hotpoint CTD40P tumble drier.
I seem to be having problems with a machine I have come across, it’s a three stat version that occasionally provides heat, thermostats all appear to be ok, I’m right in thinking that the white sta should be open circuit aren’t I?
Have you checked the integrity of the insulating band under the contact track around the drum? If there is a short here it will affect the heating…..:wink:
Hi mark the machine sounds like it has 2 stats and a thermistor
the thermistor is usually one piece moulded
unlike the stats if both stats are ok it could be the thermistor
some hotpoint machines have a front one as well as a rear
