Manufacter alloy tub pulley sunken Screw
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Manufacter alloy tub pulley sunken Screw
  • #17925
    whitevanman
    😡 Does anyone know why manufactures are using this type of Screw bolt with Allen key required,when trying to remove the only thing that happens is that the hex hole rounds off even when heat is applied., even tried a chisel but alloy disintegrated.
    Any tips greatly appreciated.
    Or is it there attempt to prevent repairers to provide a cheap an effective repair
    Model AEG 76669 Lavamat
    Wayne
    #177055
    Simon46
    Re: Manufacter alloy tub pulley sunken Screw
    And does an impact driver work?
    S.
    #177056
    wilf
    Ive posted here before about this. heat it ,hit it, try as you like but forget the allen key get a socket mounted 6mm I get them from justoffbase-tools.co.uk
    wilf
    #177057
    whitevanman
    wilf wrote:Ive posted here before about this. heat it ,hit it, try as you like but forget the allen key get a socket mounted 6mm I get them from justoffbase-tools.co.uk
    wilf
    Thanks wilf
    but I should of said it was a 6mm key in a socket, the alloy just breaks up and round the the hex hole up, do they use a metalic super glue /loctite to stop the screw from comming out.
    #177058
    whitevanman
    I think that even this brand including indesit & Servis group should also carry a public weath warning saying :-
    “Dont purchase this brand as we are trying to make it increasingly difficult/expensive for our machines to be repaired as we dont care about the environment or your finances only our operating profits/margins thats unless you want to take a five year waranty with our insurance allies to make exceedingly good profit to pay our directors/managers, and wish to make your local engineer forced in to working with us or buying a franchise thus holding him by the Nuts, either way we win!”
    “We will therefore control every whitegoods repairer in the land and will manage his finances for him and give him some pocket money for him thats only if he begs and does what we tell them to do”.
    Wayne
    #177059
    squadman
    No doubt about it this arrangement is a pain in the ****, however I have used quality socket bits to remove the pulley bolt and as we all know you either end up round the bolt off or breaking the socket bit:
    My solution is to use a sharp chisle and get a firm hold in the bolt first, by then applying short sharp blows I then get it to turn a few times. Once you get to this stage the correct tool i.e a socket based allen can be used to fully remove the bolt.
    I have not had one fail me yet using this technique:
