Hello,
i have a washer/dryer of the above model, Everything works ok except the dryer, it gets hot but everything comes out hot and steaming wet.
There are no error codes and the filter on the front is clear and free flowing.
Is this type of dryer a condensor type? is there a condensor fan or anything to check, i have three dogs and it gets alot of dog hair going through it.
I think you have an AWD12SUK, this is a condensor dryer. You could have a blocked condensor, quite common on these, also a failure of the cold inlet valve to the condensor can cause this fault. Please remove the plug if you intend to investigate further or try the link in my sig to see if we have someone who can help. Should not be over expensive to fix.
