Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › matrix dishwasher
- This topic has 10 replies, 6 voices, and was last updated 18 years, 5 months ago by
fasetester.
October 20, 2007 at 12:10 pm #31535
fasetester
Participanthi guys have to repair a intergrated dishwasher the said the make of the dishwasher is a matrix mod mx194. the problum is it flashes 3 lights pots plates cups and think the said it beeps when closed any help welcome fasetester 🙂
October 20, 2007 at 12:18 pm #231584Penguin45
ParticipantRe: matrix dishwasher
Probably Chinese, probably a flooded base.
Do yourself a favour and say no………..
October 20, 2007 at 1:18 pm #231585fasetester
checked the are made by cda why chris are the hard to work on. another site is selling them £269.00 with 5 yrs parts guarntee. does any one have the fault codes thanks fasetester.
October 20, 2007 at 1:24 pm #231586Penguin45
CDA don’t make anything – they own the Matrix name, which they stick onto the front of Haier dishwashers.
http://www.ukwhitegoods.co.uk/modules.p … dishwasher
Put ‘Haier AND dishwasher’ into the search facility – it makes appalling reading.
Fault codes are at the bottom of P2 in Known Error Codes.
October 20, 2007 at 3:23 pm #231587DentedPorsche
It is a Haier, I was unfortunate to be sent to one these. Crap copy of Merloni machine. Can’t remember what lights were flashing but it was a faulty tube heater.
Brian
October 23, 2007 at 4:06 pm #231588fasetester
wel guys went to this matrix dishwasher today. pulled it out tipped it back sure enought base flooded. got it to run let run for about half hour or more took off both sides checked all over for leaks seemed ok. ajusted up feet to put back in when i got it pushed back in and tryed to ajusted feet the back one on the right would not ajust back down is there a secquince in which the feet should be ajusted thanks fasetester
October 23, 2007 at 4:12 pm #231589maltheviking
DentedPorsche wrote: Crap copy of Merloni machine.
That’s going some 😆 I never thought you could get anything more crap than a merloni 😆
October 23, 2007 at 4:42 pm #231590Martin
fasetester wrote: is there a secquince in which the feet should be ajusted thanks fasetester
No fase, each foot is adjustable seperately 😉
October 23, 2007 at 4:56 pm #231591fasetester
thanks martin for your reply. does it matter if you ajust the back first and then the front. the back ones are screwed like a jack leg. and the frount ones you have to use a spanner but the back right one will not screw down. it went up ok but wont screw down . fasetester 🙁
October 23, 2007 at 5:26 pm #231592Madmac
Probably stripped thread,think ive had that with one or two in the past.I would ask what shes using in it as well,given the unexplained flooding. Some fairy products seem to make the best behaved machines spew up.
October 23, 2007 at 7:01 pm #231593fasetester
just det block not 3 in one how did you sort the stripped thread mad mac then again might not use rince aid or salt.
