Matsui MF160 thermostat confusion / safety issue?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Matsui MF160 thermostat confusion / safety issue?
  • #66509
    No heat and found the non self-resetting 90deg stat tripped. (It is not manually resettable either.)
    Got stat kit from Connect part no. MDI674000900009 (the I might be a 1, there’s no sure way of telling.)
    Connect’s yellow label on packaging states: “thermostat kit contains 1 x non self r.. ” (runs out of characters).
    But this is what I find:
    Well, I decided to fit it for now, warned customer to keep an eye on it until I get back to them with an answer from Connect. In the meantime, does anyone here know about this?
    Mike.
    #364385
    adv
    Re: Matsui MF160 thermostat confusion / safety issue?
    Hi mate at this job now how you which ones which ? The one at very back of dw is gone is that the 90 or 170 one lads help?
    #364386
    They’re both at back. It’s marked on them which is which, just like in my picture. The 78 deg is left looking from front of m/c. The 90 deg non-resetting is on right. That’s how it was on m/c I worked on. Cannot guarantee it for your m/c.
    Edit: Anyway, you should replace them both, that’s why they’re sold as a kit.
    Mike.
    #364387
    adv
    The old ones have no temps on them? That’s thproblem
    also ma kit has one at 170 and one at 90 a hink is this the wrong kit for this me167400090009 for a matsui Mf145?
    #364388
    Yes, looks like you have wrong kit. Should be 78 self-resetting 90 no-self resetting. Just checked on Connect – same kit for MF145.
    Mike.
    #364389
    Ah but put your glasses on! Picture on Connect shows Tf78C
    You must be seeing 170
    Mike.
