matsui mf2s/a
  • #79759
    clockworkone
    This d/w will run forever with no heat.Heater fine.Thermostat(cry682050280016) screwed to underside is o/c.Should these be in closed or open circuit.Paul
    #410465
    Re: matsui mf2s/a
    I have no clue but logic would suggest it would be a TOC in which case it should be closed. If it is wired in series with the element then that is a dead giveaway. 😉
    #410466
    clockworkone
    Re: matsui mf2s/a
    Thank you Martin. Dont get many of these over here.
