Good evening all,
Has anyone come across a programme problem with the above m/c?
When a programme is selected, the unit fills with water correctly, and then washes for around eight to ten minutes.
Yet, it then drains and aborts the cycle… water still cold
I suspected the heater element (exposed type)but this tested, and appears ok.
Am I correct in now suspecting the timer/ecu,or is there somewhere else one should be looking also?
Thank you,
jontymox
