Matsui MF2W/A stuck in cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Matsui MF2W/A stuck in cycle
  • #46982
    wilsonqc
    When using the main washing cycle the machine gets stuck part-way through and will not complete. Any thoughts on isolating the problem and fixing it? (Plumbing / electrical knowledge / experience approximately nil!)
    wilson
    #291846
    Re: Matsui MF2W/A stuck in cycle
    It’s a mechanical timer Chinese one, so there is a very common problem which pops up regularly.
    Is the water getting hot at the point at which the timer stops? The timer stops until the thermostat completes the circuit at the right temperature and restarts it.
    If “No”, you’ll need one of THESE LITTLE CHAPPIES – the thermal safety cut-out. They fail for fun….
    Stay safe, power off if you intend to deal with this yourself.
    wilsonqc
    Thanks for the quick response – probably best for a chap like me to get a man out to fix that kind of stuff.
    #291848
    Click “Find an engineer” and enter your postcode to find ypur local UKW repairer.
