Water is not going in fitted new inlet valve solinoid but still no water going in. The control on this model is a turn knob, ive tried advancing through the cycle water pumps out but no water going in ?
The circulation pump was not running, turned the end with screwdriver and then all worked fine. This must mean the pump needs to spinn before the water is let in ! Thanks for your help, Penguin 45. 🙂
It probably just needs a new start/run capacitor. The value in uF will printed on the case; most can be found in the Shop@ facility in the dishwasher universal spares section.
Being a Chinese jobbie, I’d be very wary of spending any real money on the thing.
