Re: Matsui MSI60SL programme not moving on
Oh joy – another Chinese one.
Safety cut-out tripped most likely. Remove left hand side panel to access and push the button (With the power off, of course.). Some of these are non-re-set and have to be replaced – contact spares@ukwhitegoods.co.uk if you need to order a replacement.
Curious that the timer will not advance from any position. Normally, clicking it past the heat positions should allow it to run on.
Just for fun, put ‘Haier AND dishwasher’ into the search facility for this forum only to see what you’re up against.
These little horrors are £180 for a reason……….
