Max Dimensions for Undercounter Fridge
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Max Dimensions for Undercounter Fridge
  • #78138
    ronanmcd
    We have an old Siemens FD8508 undercounter fridge that we inherited from the previous owners. It has been giving us problems recently, so we have decided to replace it. It appears to be 84cm high and has a cabinet door that is 60cm wide. The worktop is 85cm from the floor and the opening is 60cm wide, so some of the models that we have looked at will not fit the space. Having read the installation advice of this website, I am wondering what is the maximum height that we should consider when reviewing product dimensions, and are there any other factors that we should consider. If possible, we would appreciate advice on models that we might consider.
    #404619
    don
    Re: Max Dimensions for Undercounter Fridge
    Under worktop refrigeration are all around the 85cm high mark. Worktops are normally set 86cm to 87cm from the floor to the underside.
    It may be worth rechecking your height again 😉
    HTH 🙂
    Don
