Home › Forums › Public Support Forums › Spare Parts Help › Maxol Majestic Duo – Electronic timer
- This topic has 16 replies, 4 voices, and was last updated 21 years, 10 months ago by
admin.
June 9, 2004 at 1:21 pm #5608
KeymasterI need to get a new timer for this oven, can anyone help me ?
June 9, 2004 at 2:04 pm #112129Dave_Conway
ParticipantRe: Maxol Majestic Duo – Electronic timer
Possibly, although I believe these are now rather old.
If you could find the model number, serial number, gas council (gc) numbers it would be a help as I doubt that there was only one version made.
Regards
June 9, 2004 at 3:21 pm #112130admin
KeymasterRe: Maxol Majestic Duo – Electronic timer
the part number I have is 3/10701/0 and I have a G.C No 397 922
June 9, 2004 at 3:23 pm #112131admin
I forget the model number, its G.C No. 11.202.06
June 9, 2004 at 11:11 pm #112132Penguin45
ParticipantIf the timer is obsolete bear in mind that QER at Workington offer a repair service to most electronic cooker timers. I think there’s a link in the database somewhere.
Penguin.(Pull the plug first)
June 10, 2004 at 9:38 am #112133Dave_Conway
I can’t find any reference to it, so it may well be obsolete.
As Penguin mentioned, in the links is a company called QER who repair these sorts of things, send the timer to them they should be able to effect a repair for you, assuming it’s an electronic timer and not a mechanical one of course.
And, yes, pull the plug !
June 10, 2004 at 10:51 am #112134admin
Thanks for all your help
I have contacted QER and I shall be sending the unit to them for repair.
June 10, 2004 at 11:08 pm #112135Penguin45
ParticipantLet us know how you get on. We love a happy ending!
Penguin.
June 30, 2004 at 12:47 pm #112136admin
I also have the same oven. But I need a new unit for the controls and regulators etc. Apparently it is all one unit, and I have gas leaking form mine.
I do not have a manual of part numbers, so may be left with needing to buy a whole new oven – ouch!
Any ideas?
June 30, 2004 at 1:03 pm #112137Dave_Conway
JEF wrote:and I have gas leaking form mine.
Has it been disconnected from the gas supply by a Corgi registered engineer ?
JEF wrote:Any ideas?
Sadly buying a new oven is the only option it would seem, as we found out for the other guy, the parts appear to obsolete now for these models.
June 30, 2004 at 9:01 pm #112138admin
KeymasterAs I feared. And yes, there was a whole saga of CORGI registered gas fitters dicsonnecting, reconnecting, replumbing etc earlier in the week. That was why I was hoping to avoid the expense of a whole new cooker. Can anyone suggest a good, reliable, cheap equivalent (fitted double oven and grill with automatic timer)?
July 1, 2004 at 7:43 am #112139admin
As it’s a double cavity, is it fitted as built in or under counter, the two appliances are different sizes ?
Built in is when it’s “up in the air” (at eye level) etc. A double cavity built under (under the worktop) is a rarer breed of appliance and the replacements will be more limited.
July 1, 2004 at 7:56 am #112140Dave_Conway
The previous post was me BTW, got logged out for some reason.
July 2, 2004 at 9:21 am #112141admin
KeymasterDefinitely ‘up-in-the-air’ with pots and pans in cupboards both above and below.
July 2, 2004 at 9:48 am #112142Dave_Conway
Oddly enough I was discussing this with Don earlier, there are limited supplies of gas double built in ovens now, hardly anyone makes them for some reason.
I’ll let him take over………….
