Good evening all,
Attended the above m/c today, and confirmed that the unit is suffering from excessive vibration on spin, especially with anything other than a well-balanced load.
The only conclusion I’ve come to is that the six springs in the base have become weak over time, as the unit is around 16 years old.
In my opinion, the tub/drum assembly can be moved far too easily from side to side.
Has anyone come across this problem, or should one renew the said springs and see if this helps?
Thank you,
jontymox
