maytag american f f
  • #30295
    paulbugman
    got a problem with fridge freezer with tripping out as soon as switch on .
    meggar it and yep down to earth , have checked compressor ,defrost heater in freezer ,thermostat in freezer and check pcb in door ie both of them but still down to earth and no problem with above ,any idea`s model is fd8212
    #226672
    gegsy
    Re: maytag american f f
    Wiring loom through hinge chaffing??
    Also need model number, usually starts G……. 😀
    paulbugman
    are they common for that and appliance is only 2 years old .
    model number gc2228gehb
    #226674
    gegsy
    Was just a thought.
    Have you looked at the dispenser area,esp PCB. Prone to leaks from poorly closing ice flap.
    Solenoid for ice flap goes awol aswell.
    paulbugman
    checked that and fine no water marks and not down on earth and yep check pcb as well and clean dry and no that .
    #226676
    ELDAR59
    the most likely cause of this would be the defrost heater, followed by the compressor, but as you’ve checked these, obviously not!
    have you checked the condensor and evap fans?
    cheers.
    #226677
    gegsy
    Have only ever had earth faults on these by the following
    1/ Defrost heater
    2/ Compressor
    3/ Ice maker Unit
    Have sent you circuit diagram by email 😉
    PS – Defrost heater was weird, leakage went acceptable when out of circuit but but when I physically meggered it, it read ok 😕 Changed it and hey presto so…………
    #226678
    paulbugman
    got to be ice maker then as try everything else and by removing defrost heater and compressor from circuit didn`t make anything difference ie still down to earth
    pm you back greg
