maytag fridge fault
  • #55616
    abbots
    hi,
    GC2227CDFB/16
    Sn.168 77916EP
    this machine has a earth fault on it.
    The evaporator defrost heater is faulty.
    i disconnected the heater and wanted to check everything else is Ok on the machine before ordering the parts but the machine will not run.
    Is this because the heater has been disconnected and there is a ‘monitoring’ circuit which stops the fridge from cutting in with the heater disconnected.
    Any advise will be appreciated.
    john
    #324511
    Re: maytag fridge fault
    a lot of machines these days do a check of componebts before start up so it is possible
    can you either
    A place the defost heater so it is not earthed
    B disconnect earth of the whole appliance
    this is for check purposes only i am in no way telling you leave the earth off the machine so it will work
    i do the same on indesit washers when the earth fault in the motor causes problems
    hope this helps
    abbots
    not really dave,
    thanks for advise but i’m back in the office now and the call’s about a 90 mile round trip.
    any one know the Maytag machines really well that can advise on this please.
    thanks.
    jk
    #324513
    ELDAR59
    i think we’re over complicating this one guys.
    this appliance is a slightly older one from memory.
    it will have a mechanical defrost timer which will be in the defrost position, hence when powered up it will trip and with the heater taken out of circuit it won’t run.
    replace the heater and you should be ok.
    the timer will be in the top of the fridge compartment on the right hand side.
    cheers.
    #324514
    abbots
    top man,
    jk
