Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Maytag fridge freezer model: GC2225GEKB
- This topic has 5 replies, 2 voices, and was last updated 11 years, 6 months ago by
Grahamdust.
October 2, 2014 at 11:23 pm #82463
Grahamdust
ParticipantI have changed the PCB on this cabinet, which then requires the program code to be set. I have done this in accordance with the data sheet provided with the spare part, but it will not save the code at the end. I have noticed that the old PCB is marked as a JAZZ15 and my new one is marked JAZZ14. So now I am unsure whether I have the wrong part (although it seems to be the only one listed) or need to do something else to get the code saved. I have tried to speak to Maytag, but they will only discuss technical issues with their own engineers. I’m hoping that someone can help.
Many thanks
GrahamOctober 3, 2014 at 7:14 am #419932SAMURI
ParticipantRe: Maytag fridge freezer model: GC2225GEKB
Try default code 05 or 15 this should work.
Bob
October 3, 2014 at 11:03 am #419933Grahamdust
Thanks Bob I will try that.
Graham
October 3, 2014 at 7:21 pm #419934SAMURI
I have never found one that works with the code on the rating plate but 05 or 15 default codes normaly work let me know how you get on.
Bob
October 15, 2014 at 5:39 pm #419935Grahamdust
Thanks very much for the advice Bob. I was unable to reply until now because the customer was away. So on his return I rushed round to put your default code into practice, and it was saved immediately and the cabinet is now working again.
So again thank you very much I don’t know what I would have done without you. Its wonderfull to have somewhere to turn, when the manufacturers back up is lacking.
Regards GrahamOctober 15, 2014 at 11:11 pm #419936SAMURI
Thanks for the update.
Glad to have helped
The Manufactures are no help to us unless you are employed or contract to them.
Hotpoint are now making it difficult by only supplying unprogramed PCB’s on there refrigeration and you cannot program them without the software.
It will only add to the landfill if manufactures do not help the indipendent repairers
Bob
