Maytag Fridge Freezer not running
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Maytag Fridge Freezer not running
  • #35358
    pete-c
    Model GC2224GEKB Lights are working,also lights on door chilled water panel. The thermostat displays are not working and the fridge and freezer are not working. Have checked the pcbs and cannot find any obvious faults. Should i replace both panels and who can supply them
    Pete
    #246203
    sorted
    Re: Maytag Fridge Freezer not running
    The pcb boards come as one unit called a( jazz board)
    available from MaytagTel 01737 231 000 comes with instructions to fit.
    Very simple to do but you must programme the new board with the code
    No, which is listed below the model No, on inside of fridge.
    Stephen.
    #246204
    pete-c
    Stephan
    Peter
    #246205
    Simon46
    Did PCB fix it? I have one the same.
    S.
    #246206
    Simon46
    Fitted/configured Jazz board. All ok
    S.
    #246207
    funkyboogy
    an yone got a part no for jazz pcb i have gc2224gekv model
    lights only , if you open fridge door compressor comes on
    cheers ally
    #246208
    lokring
    12868513
    #246209
    funkyboogy
    cheers and cheers again to whoever mentioned entering 0 5 to configure pcb , as it would not accept 2 8 which serial badge states ..
    ally
