Maytag frost free double door GC20C7C3EB
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Maytag frost free double door GC20C7C3EB
  • #36511
    boselecta
    Maytag frost free double door GC20C7C3EB / 10486687SY REV 10
    Saw this appliance today the evaporator is tottally iced up, dont think defrost heater is coming on. There are two defrost elements in parallel the bottom element (in glass tube) looks burnt at both ends. elements 75Kohms TOC 95Kohms.
    Unable to meter out individual elements as contacts have plastic moulding on them.
    Has anyone else had this problem with the defrost heater unit and what is it like getting parts for this make as havn’t really worked on them before?
    #251323
    ELDAR59
    Re: Maytag frost free double door GC20C7C3EB
    this is a fairly common problem, the defrost heaters being the most likely cause.
    they’re in series though, not parallel. the terminals are located at the top of the evaporator on a little piece of what looks like mica board.
    the readings you give seem a little high, normally they go o/c, although i had one the other week where the readings were very high.
    the part no for the heaters on this model is 61002102.
    the defrost stat should read through when cold and be about 250k ohms when warm.
    there is also a defrost timer located in the top of the fridge, behind the thermostat housing. these are normally reliable.
    any one, or even any combination of the above cold be causing you problems.
    hth,
    cheers.
    useful site for maytag products is http://www.partsprofile.com
    #251324
    boselecta
    thanks alf that looks like a good website to get Maytag bits from
    #251325
    ELDAR59
    well it would help with the parts identification, you’d have to give maytag uk a call for the bits.
    that’s a us based site, but as you say, very handy.
    cheers.
    #251326
    boselecta
    Have been trying all day to order this part from Maytag uk.
    There call center is rubbish, I cant find anywhere else in the Uk where I can get these parts, anyone know anyone where i can get these parts from?
    #251327
    ELDAR59
    you could give bradshaws a call. i think theyre based in bristol.
    01275 343000
    #251328
    The GC20 is the slimmwer of the freezer sections and should be the 61002101 part number alf ?.
    If needed I have about 10 sets still in stock.
    Bryan
    #251329
    ELDAR59
    the c6c would be the slimmer model bryan, this is the c7c, which takes the longer heaters, 2102.
