Maytag G32026pelb
  • #43779
    geoff1
    Any one help
    Customer has fitted new module inside top of fridge and now cannot adjust temps plus unit is not running.(2nd module supplied by Maytag)
    Seems simple to fit as it has only 2 plugs but does it need to have any set up done? Is there a diagnosis programme that I can access as I think the original fault is not module related?
    Customer has thrown old module away and Maytag are not being helpful.
    Can you help?
    Regards
    Geoff
    #278556
    geoff1
    Re: Maytag G32026pelb
    Sorted
    Module programmed and original fault – compressor buzz click, buzz click 😥
    Geoff
    #278557
    SWERV
    We have been out to one of these that needs a new board, does it need programming?.
    Merv
    #278558
    geoff1
    Yes it does. I found the information rhs behind the kickplate stuck in bag just above condensor coils. tight squeeze.
    If they are not there let me know and I will see if I can get copy.
    Easy to programme using switches
    Geoff
    #278559
    johnsdad
    programming instructions normally come with control board
    #278560
    SWERV
    Thanks for that, nice to b armed!
    Merv
    #278561
    SWERV
    Hi Geoff, we didn’t get the programming instructions with the pcb and we couldn’t find anything in the machine. Do you happen to have a copy??
    Regards
    Merv
    #278562
    geoff1
    I will check to morrow and let you know
    Geoff
    #278563
    geoff1
    Hi Merv
    Checked with customer had they have been disposed of. I did not know if I should laugh or cry.
    Programing instructions are only found hidden behind the kickplate stuck up above condensor coils. Easy to miss as they are stuck up in plastic bag.
    Sorry I could not get
    Geoff
    #278564
    SWERV
    Thanks for checking Geoff. If anyone else might have a copy, it would be greatly appreciated.
    Regards
    Merv
    #278565
    SWERV
    Bump?
