Maytag G32026PELB
  • #44225
    nigegt
    Freezer fan not running, motor tested ok any ideas. Evap not frozen up defrost heater ok.
    Cheers
    nige
    #280253
    ELDAR59
    Re: Maytag G32026PELB
    hi nige, the problem will be the board.
    also worth checking the resistance of the fan motor before fitting new board, because the fans can be almost short circuit.
    cheers.
    #280254
    spimps
    I have in some instances traced the fan supply back to the board and linked it to the compressor supply. It means there is no fan delay in comeing on, but it’s a cheaper option than a new board sometimes,have been doing this on many but not all occasions for quite a few years and have had no problems at all.
    #280255
    ELDAR59
    this is the trilogy model, side by side refrigerator with bottom mount freezer with sliding drawer. it doesn’t have fan delay.
    if you look behind the plinth, underneath the machine, you’ll find a wiring diagram stuck to the bottom of the cabinet.
    the fan connections on the board are clearly marked on it.
    piggy backing a supply may be a cheaper alternative, although never encouraged by the manufacturer and given the price of the appliance, probably not the customer, either.
    also, you may still have the possibility of the fan being short, as mentioned before.
    #280256
    nigegt
    Brill thanks very much guys
    Nige
