maytag G32026PELB
  • #62038
    gav28
    Hi having a nightmare with this machine first visit faulty pcb would only work with doors open. Replaced then evap fan o/c replaced. Now evap fan not turning on get live feed to both connections. Does anyone have resistance readings for freezer ntc?? as i dont know if faulty pcb or sensor.
    #348462
    johnsdad
    Re: maytag G32026PELB
    The original faulty fan has probably damaged the board, look for a burnt/open circuit resistor nerar the top edge, normally coloured blue
    #348463
    ELDAR59
    check the resistance of the fan. you’ll probably find it’s nearly short.
    #348464
    gav28
    Thanks guys for your help when i fitted new pcb had left old motor on whoch must of damaged new pcb. Changed both pcb and motor now working fine
